McMark
Feb 7 2004, 04:04 PM
Let's compile a list of rubber pieces we would like reproduced and I'll look into costs and such. What's not available aftermarket?
1. Firewall wiring tube.
2. Bushings where fuel lines pass through the engine sheet metal.
Keep 'em coming.
sj914
Feb 7 2004, 04:15 PM
Rear tail light housing gaskets. Haven't seen them.
RustyWa
Feb 7 2004, 04:20 PM
At a bug shop, I saw a grommet that looked exactly like the fuel line through the engine shelf grommet. I think it was for a bug speedo cable or for a bus or something. Was just a few bucks.
I'll take a better look next time I go there.
JFJ914
Feb 7 2004, 04:22 PM
QUOTE(markd@mac.com @ Feb 7 2004, 02:04 PM)
You can still get the fuel line grommets , 111 957 861, from the dealer. They were $2.10 ea on 12/8/03. They are also used for the brake reservoir to M/C lines through the chassis.
RustyWa
Feb 7 2004, 04:25 PM
There you go...
McMark
Feb 7 2004, 04:36 PM
I was planning on persuing dealer supplied parts first, then going custom. But I'd like to get a nice list of the things people can get, or don't think they can get.
Aaron Cox
Feb 7 2004, 06:00 PM
how about GOOD windshiled/a pillar/targa seals
JeffBowlsby
Feb 7 2004, 06:18 PM
I can think of a few...
Alternator cable grommets at the engine tin.
D-shaped ECU grommet min FI harness
Big O grommets at the heater J-tubes throught the engine tin.
Rubber boot cover at the alternator cable to starter solenoid
tracks914
Feb 7 2004, 06:35 PM
QUOTE(John Jentz @ Feb 7 2004, 02:22 PM)
When I pulled apart my parts car I found the brake line grommets and put them aside. When I put the car back together and asked for firewall and fuel pump pictures, (mine was all gone when I bought the car) I noticed that they fuel lines grommet were the same.
YaHoo, something I didn't have to buy.
type47
Feb 7 2004, 07:12 PM
i found the grommets for the fuel line thru the engine shelf at west coast metric. this is my best find:
http://forums.pelicanparts.com/showthread....ighlight=J+pipethey fit MUCH better than OEM grommets, so tight you almost can't install them. not for the CW though.
ChrisReale
Feb 7 2004, 09:43 PM
how about the Grommet that the CHT goes through on the engine tin...
IronHillRestorations
Feb 7 2004, 09:53 PM
You'd be suprised what's still available from Porsche. The grommet that goes throught the engine shelf (for the fuel line), is still available, and it's not too bad. More and more of them are going NLA though.
Steele rubber makes an excellent assortment of good rubber grommets. I get them for wiring, oil lines, etc. They have a nice one that is perfect for the wiring harness through the left side 914-6 engine sheet metal.
PK
JeffBowlsby
Feb 7 2004, 10:01 PM
PK
Could this be...no couldn't be...
Are you the one and only Perry Kiehl???
andys
Feb 7 2004, 10:14 PM
What about the rubber gromments/buttons that hold the bezel just ahead of the headlight doors. Are the still available, and where? If not, how do you suggest fastening them in place?
Thanks,
Andy
Brad Roberts
Feb 7 2004, 10:46 PM
Chris,
the grommet for the CHT is still available.
B
JeffBowlsby
Feb 7 2004, 11:11 PM
Yep they are. Get the PN and order them.
hargray2
Feb 8 2004, 08:15 AM
Is the L-shaped boot for side marker light wires available.
Feb 8 2004, 09:03 AM
[quote=bowlsby,Feb 7 2004, 08:01 PM] [quote]PK[/quote]
Are you the one and only Perry Kiehl??? [/quote]
[/QUOTE]
ever since I was a kid!
PK
Feb 8 2004, 09:04 AM
QUOTE(hargray2 @ Feb 8 2004, 06:15 AM)
those are not. I got ten about eight years ago, and have only two left for the "black hole".
PK
andys
Feb 9 2004, 12:41 PM
QUOTE(bowlsby @ Feb 7 2004, 09:11 PM)
Andy
9146986,
When you say get the PN, do you mean these are available at the dealer, or through one of the parts suppliers? I looked on-line and couldn't find them....any help would be appreciated.
Thanks,
Andy
maf914
Feb 9 2004, 01:43 PM
Fuel line thru engine shelf. Also thru front and rear firewalls.
http://store.cip1.com/Merchant2/merchant.m...de=11A-01-01-05You can go to the 914 PET CD and record all of the grommets for the engine tin. Then go to the local VW dealer and order them, as they are all VW numbers. I did this and ordered about $40 worth. This included the CHT grommet, the oil pressure boot, and the J-tube grommets. But it didn't include any of the rear tin grommets, I had to reuse the old ones.
Mike
RON S.
Feb 9 2004, 02:17 PM
1. How about the boot for the speedo cable as it passes thru the firewall.
2.Also the boot for the backup light switch at the trans.
Ron
Aaron Cox
Feb 9 2004, 04:39 PM
Ron, youre (1) comes with a new speedo cable
F4i
Feb 10 2004, 12:45 AM
QUOTE(acox914 @ Feb 9 2004, 03:39 PM)
True but they put it on the wrong end.
RON S.
Feb 10 2004, 05:55 AM
Who wants to buy a whole speedo cable when only the boot is bad?
Ron
JeffBowlsby
Feb 10 2004, 08:32 AM
Also still avaialable.
