QUOTE(mattp @ Oct 7 2008, 04:13 PM)
Got the car running great finally, Raby 2056, new webers, hex bar linkage.
Got the carbs balanced, it runs smooth and strong, BUT....
after running it for a bout 20 minutes the car will not return to idle, the linkage sticks with just a tiny bit to go before going back on the stops. It only happens when warm and takes just the slightest touch on the linkage to get it to go back?
Should I go with a heavier return spring? Not sure thats the best, seems to be covering up instead of fixing the problem.
the problem is that the drop links are not on the same plain when looking front to back and or side to side.
This will bind the drop links (one of them)
First make sure they are both at the same angle side to side...first step.
Then find a place to measure to front to back on both the top and bottom of the drop link...the centerline of the fan shroud is good, or the rear of the engine bay (there is a vertical portion of the firewall at the trunk.)
Take a look at this link and you will see what I mean and how to fix it..
http://www.356registry.com/techinfo/repair...er_linkage.htmlThe exact same principles and solution apply to the 914...but this link has pictures.
rich
