QUOTE(orange914 @ Oct 8 2008, 01:07 AM)
QUOTE(yellow1 @ Oct 7 2008, 09:26 PM)
.I have read in some threads that temp compensating gauges are much better than the vdo gauges.
and is there a special wire for it to work in the 914 ,
MICRO 1000 CHTif i had it to do over i probably would have got a temp. comp. gauge. although as i understand the NON temp. comp. is set with the base temp. @ 70*, meaning adding additional temp. (difference) above 70* or subtracting from ambeint temp (difference) below the same way.
i did get a duel guage that i really like, if for no other reason i can get a better overall picture. you can even get a 4 way switch and hook al 4 cylinders up.
there IS special wire. this can be the most expensive part of the set up. there is k type and j type. from what i've read the k type is more sensitive at lower temp's. it seems more avalible but seems even more expensive than j type. you have to use spacific wire depending on gauge requirement. my non comp. gauge used j type and after searching EVERYWHERE i found some and bought twice the amount i needed. as i recall it ranges around $3+ a foot. i've got 20 feet if you need to purchase some j type.
It may be overkill but it will be fun.
Talk to me about a good way to wire up four temp sensors to one gauge.
Ideally I would like to have a four position switch next to the gauge that I can flip from one cylinder to the next...again, just for fun.
I have thought about this quite a bit and I am worried that the sensor wire issue may create a problem due to amp loss through the switch.
I did see a four position gauge but I would drive off the road trying to read the damn thing..its tiny.
A digital one would be perfect...of course temp compensating...but I cant find one of those either.
I wanted to add this setup, a fourway EGT setup and an AF gauge...
Put all of those in the stock center console.
Rich
