QUOTE(GLENN914-6 @ Feb 7 2004, 05:42 PM)
Thanks guys, at least I know now that it can be done!
...do the ball bearings go between the cage and axle or around the outside of the cage
it fell apart by itself with virtually no pressure - it will go back together the same way - no force involved.
basically, a Löbro CV joint is a fancy ball bearing that has no rotational movement between the inner and outer races.
the balls fit inside the cage - the cage holds the balls around the middle. once you've got it, it's usually easier to do them dry, but until then, it may be useful to use a little sticky grease to help hold things together during that 'i need 3 hands' part.'
if you think about how it came apart, you'll come to understand the relationship of the 6 balls and the way the inner race pivots into the outer race from 90 degrees. two balls - top and bottom, hold cage and inner race in place. the two balls on one side (i don't know which way you're holding it ...) come in up from the bottom, while the two balls on the other side go in down from the top.
you'll see the matching pattern of grooves the races form. more than that is just about impossible to describe in words - you really need the picture... surely there's one on the Pelican site tech articles somewhere ...
