ThinAir
Feb 8 2004, 01:13 AM
I'm starting to rebuild my stock FI 2.0L. I'm pretty sure that a set of 96mm Nickies and pistons are not in the picture at $3,000, but I sure like the idea since I'm in Arizona and heat is always an issue if I come down off the mountain.
So if I can't do Nickies, what's the next choice? Euro domed pistons? If so, is there a cylinder choice?
What I'm after is a solid daily driver that is going to have the greatest longevity possible. If I get a little better performance out of it than the straight stock engine that's fine, but not necessary.
What do you guys suggest?
Brad Roberts
Feb 8 2004, 01:14 AM
Mahles or the Jap knock offs. They are the only game in town. You could have a stock set of Mahles enlarged to 96mm and use the KB pistons.
B
ThinAir
Feb 8 2004, 01:23 AM
I only mentioned 96mm because Nickies don't come in stock 94 size. From what I've read here the FI wouldn't even flinch at the extra 2mm per cylinder, but unless theres a compelling reason I'm not interested in modifying Mahles just to get the bigger size.
Why should I want to move up to 96mm?
ChrisReale
Feb 8 2004, 01:58 AM
What about Kolben Schmidt (sp??)
Brad Roberts
Feb 8 2004, 02:04 AM
No real reason. The 94's work fine. The Jap 96's are cheap at 350$ or so. The Mahles (Euro) can run up to 525$ or so.
I havent seen anything from Kobel in awhile for our cars. They might still be avaliable.
B
ChrisReale
Feb 8 2004, 02:14 AM
KS. I got them in my car, the same company that makes all the bearings...
