QUOTE(Trav012000 @ Oct 10 2008, 03:37 PM)
Hey guys, I need a bit of info here. I just got my 914 off ebay a few weeks ago and since then i've been doing some minor and major surgery. I'm under the dash right now trying to figure out the problem that's causing my radio to short out every time I try to turn on the wipers.
Anyway, I was under the dash when I found a wire that wasnt hooked up to anything. Upon investigation it seems to be attached to the top left of the speedo gauge if you're looking at the back of it. My best guess from what I can see and what i've been able to find online (next to nothing) is ground.
If you need any more information just ask, I'll do what I can to clear up any questions.
Thanks in advance.
It sounds like the power wire for the radio is hooked up to the wrong side of the wiper fuse on the fuse block.
Look at the back of the fues block (two screws take it down and let it hang so you can work on the back of it)
You stereo should have an inline fuse for contant power (memory), keyed power (main power) and antenna power.
The contant and main power leads should get plugged into the fues box on different tabs, but they should not be using the main fuses..they should be plugged in on the constant power side of the fues panel...
Rich
