I'm getting steering wheel vibration at 55-70 mph on 25" dia tires.
Ran out of things to check.
Had the tires balanced, checked hub bearing play, shook the struts with no movement, steering arm joints ok, 1 rubber steering joint was worn so I replaced it and other side checked ok although it was hard.
I don't remember the tooth mesh being adjustable. I also didn't get a good check of the strut ball joint since the arms are tensioned.
Any ideas??
Thanks,
Chris
