I have totally stripped out the interior, sorted any rust (er... none ) dynamatted the whole interior, put in extra soundproofing, fibreglassed over and repaired the back pad where the board/wood had perished and fitted a new grey loop carpet set from Appearance and Performance, phew. Looks fabulous and returning to perfect condition
Now as I understand it, the dashboard levers work like this...
1. Top lever
FRESH air vent and fan control
2. Middle Lever
Controls direction of FRESH air delivered by above lever (left footwell, right dashboard.)
3. Bottom Lever
Controls direction of HEAT from 4 below. (Again far left footwell, Right Dash vents)
4. Lever between seats
Controls rear fan and therefore HEAT into cabin.
So the front fan plays no part in heating the car whatsoever, just FRESH air.
HEAT is controlled directly by the lever between the seats (the direction of which is controlled by the 3rd land lowest lever on the control panel)
So, if I am correct with the above can you tell me why hot air only comes from the drivers side? It is really hot air on this side and blown with quite a force, yet the passenger side is cool.. I know there are differences between 73 and 74 cars in that the earlier cars (like mine) have a rear fan that only blows down the drivers side and later cars had a T piece which splits the air from the blower and connects to the passenger side, but is this why it is cold on the ps?? Surely it wasn't that bad from the factory in '73??
Long post sorry, but hopefully concise regarding my problem.. My wife is an Aussie and is complaining that she gets cold, so I'm determined to get more heat on her side if possible.
Cheers
