Full Version: Clutch cable pic needed
Phoenix-MN
Anyone have a close-up picture of how the clutch cable is held in place on the pulley bracket? I've found references to a "retaining clip" but have had no luck in finding it or how it attaches.
Thanks
Paul
IronHillRestorations
It's a washer with a tab that folds around the cable bracket and goes into the hole adjacent to the cable notch. I'll see if I have a pic.
jimkelly
http://www.pelicanparts.com/catalog/images..._stop_plate.JPG
per pelican
Phoenix-MN
So, when you install this do you just bend the tab over to fit in the pulley braket?
Thanks
r_towle
Yes, you bend it around the outside of the housing and then bend it into the little hole for the end of the tab on that washer.
Rich
Phoenix-MN
