Ladies & Gentlemen,
I need a little assistance figuring out a problem with my 1975, 2.0, 914, Little Red. He is refusing to start and it appears that it is a fuel pump problem. I have tested the relay board and all the circuits are good and appear to function properly and the wiring from the relay board to the fuel pump is good. The problem appears to be a lack of ground on pin 86 of the fuel pump relay. The circuit diagram that I have indicates that this should go to ground through terminal III at the lower left hand corner of the circuit by grounding through pin 19 on the computer/brain.
I have checked continuity between terminal III and pin 19 and it is good. I can make the fuel pump relay kick in by using a test light to ground with the key on. I think that I may have fried the computer/brain when I was trying to solve another electrical problem, but don’t know how to test this component. Is there away to test the computer/brain, and if not where can I get the unit repaired?
Thanks for you help.
Tom Cooper
