QUOTE(Brett W @ Oct 22 2008, 01:21 PM)
Stephen, if the coolant doesn't spend enough time in the radiator, not enough heat will be extracted. I have seen that on cars with no t-stat. If the fluid is exposed to more surface area for a longer period of time it will cool off better.
Short of anything approaching supersonic flow that is generally incorrect. Cars w/ no tstats can overheat because the pump cavitates w/o the large pressure drop the t-stat introduces, not because the water is going too fast though the radiator. The opposite is happening - the water is going too slow.
From an engineering standpoint, water is a fluid just like air. On a cold day, sticking you hand out the window of a moving car, no one would think that their hand would feel warmer @ 100mph than @ 10mph. Yet, somehow people think water has some magical property that breaks down the rules of physics when its in a radiator (or oil in a cooler). People jump to the (wrong) conclusion based on empirical evidence.
Brett, Im not trying to single you out at all! Im simply trying to state that something else is going on if you're having a problem. The system has to work as a whole. But heat exchangers (radiators) love more flow.
FWIW, I don't know everything:) But I am an engineer and part of my job is designing heatsinks for cooling power electronics. I used to write all the heat transfer eqs by hand. Now we use CFD software (EFDLab) and can solve complex 3d geometries. The basic idea to take from this is: If you can flow more fluid you'll get more cooling. Getting more flow is always the hard part (in both natural or forced convection applications).
