QUOTE(7TPorsh @ Oct 21 2008, 02:49 PM)
This is getting complicated. I would assume that with the ignition on, both ends of all fuses will have power...no?
It seems one of my fuses doesn't have power with or without.
Again all fuses will not have power just because the key is on. Lets run down the list.
Fuse 1 and 2 are for the high beams and only have power to them when the high beams are selected.
Fuse 3 and 4 are for the low beams and only have power to them when the low beams are selected.
Fuse 5 is for all left side park and tail lamps and only has power present when the headlight switch is in the first or second pulled position.
Fuse 6 is for all right side park and tail lamps and only has power present when the headlight switch is in the first or second pulled position.
Fuse 7 is for the trunk and liscence plate lights and only has power present when the headlight switch is in the first or second pulled position.
Fuse 8 is Keyed power. This fuse has many items onit that will only have power once the key is turned on so you should only have power once the key is in the run position.
Fuse 9 is for the optional fog lights (I believe, as my car doesn't have anything for that fuse but if I recall that is what that is for) and should only have power when the headlights are on allowing the fog lights to have power.
Fuses 10, 11, and 12 are all Battery powered fuses and should have power at all times. These fuses power things like the horn relay, brake lights, headlight motors and other things that will always need power regardless of the key position.
I hope this helps clear things up for you. So yes you should have some fuses with no power going to them, it is just a matter of are the correct ones getting power or not.
JIM
