QUOTE(ArtechnikA @ Oct 23 2008, 04:54 AM)
A spacer can be inserted into the original caliper to widen it for this purpose. You may need to run a thin spacer between the hub and the rear wheel, so be aware of lug thread engagement issues. The usual brake-upgrade suppliers are typically set ip for this. I'd probably start with Eric at PMB or Jerry Pateman...
That would be Eric or myself. The stock 914/ 4 can be widened for this purpose, or the 914/6 can also be widened. Both keep the stock emergency brake. Or you can use a 911 rear caliper (same as 914/6 pads & pistons) and fab up your own emergency brake. Use the typical 911 rear rotor (20mm version 69 to 84).
