QUOTE(Todd Enlund @ Oct 24 2008, 01:52 PM)
QUOTE(ellisor3 @ Oct 24 2008, 05:52 AM)
Can I simply assume a smaller backspace (offset) and add spacers if I am too short?
Don't confuse backspace and offset. A smaller backspace will move the wheel out, so the smaller your backspace, the less likely you'll need spacers... and the more likely it will hit the fender. If you are having custom wheels made, you really don't want to be running spacers... that would kinda defeat the purpose of custom wheels.
A smaller offset moves the wheel towards the center of the hub, which will also move the wheel out, but it's a different measurement. Offset can even be negative.
Do you have the flares on the car? What width wheels do you want to run? I'd do a mockup to make sure you get what you want. Mount some wheels, measure clearances, and do some math. I'll be doing that when I get to that point, but it's a long ways away... I pretty much figure on 7" front and 8" rears, and I won't be having custom wheels made. I am considering a non-Porsche bolt pattern, though.
Thanks again, I do not have the flares on yet but considering the weeks are an 8 week wait, I did not want to wait until I had the flares on to order the wheels, but I may need to do that. I want to run 17x7 on the front and 17x10 on the back, I am having a hard time finding anyone who makes a 9" wheel so I am trying to figure out of the 10"will fit. Take a look at my math and tell me if this is correct in looking at the offset on the front. What I have not been able to find is the backspacing for the rear flares.
120mm backspace( 4.72)inches- ((wheel width of 7 inches (229mm) /2))=+6mm offset for the front.
Again thanks again for everyones input
