Rick,
Here's the wiring diagram for the CIS injection to get the Aux air regulator, warm up regulator and other assorted electrical issues solved.
If you wire it like it shows, and hook the Fuel Pump to the stock Fuel Pump wiring, the pump will only run when the engine is cranking or the air flow meter is lifted.
Let me know if it works.
