QUOTE(oldschool @ Nov 1 2008, 08:46 PM)
QUOTE(Type 4 Unleashed @ Nov 1 2008, 02:45 AM)
QUOTE(oldschool @ Nov 1 2008, 01:18 AM)
can any one till me what do I need to check?When am driving and am ready to go to the next gear as soon as I let off the gas I get a pop.pop sound
1973 1.7
Carbs or FI ?
A tight int valve could cause it, an air leak causing it to run lean, too much fuel.
A few things to check out first to rule them out.
yes its fi/I will check for a exhaust leak
An easy way to check for a leak is to use a rag so your hand doesn't get dirty, and if you have a single outlet exh, just cover it up, if the exh is sealed, it will run for a few seconds then die, if it's not sealed it will continue to run since the exh is getting out. It's like the old potato trick, that people useta do, stuff a potato in the tail pipe, and the car won't even start...
