vesnyder
Nov 1 2008, 07:43 AM
After almost exactly a year after initiating an engine rebuild I am about ready to claim "mission accomplished". I rebuilt a 1.8 to a carbed 1911 with rebuilt heads, agressive cam and webers. My objectives were:
> Cure massive oil leak
> Get better gas milage
> More HP to make it run like a sports car (not just look like one)
MISSION ACCOMPLISHED! After having to tear it down to re-hone the cylinders (rings did not seat first time) and spending the last 3 months tweaking the timing and carb jetting the car is running just as I expected. I had a dyno done a couple weeks ago before I had it completely sorted and I was running over 100 HP! The car pulls hard through the complete range and has an impressive top end. I am still getting a small leak and am getting close to 25 MPG. Still need to get a good timing light to set the timing correctly and maybe tweak the carb settings but it is just as anticipated.
This was my first rebuild and I am sure I made every possible mistake but I am more than happy with the results. Thanks to everyone on the board (and Jake!) for helping - could/would not have done it without you!!
johannes
Nov 1 2008, 07:58 AM
WOW great !
Can you describe what you have done to the engine to achieve theese 100+ HP. Parts used ? price ? .
And of course we like pictures here ! ...
markb
Nov 1 2008, 09:37 AM
Well done!!
r_towle
Nov 1 2008, 10:26 AM
congrats, now GO DRIVE...
Rich
bd1308
Nov 1 2008, 10:28 AM
1911 must be a really good combo then
vesnyder
Nov 1 2008, 10:04 PM
The pictures do not do it justice! The total cost was around $4k - maybe a bit more. I started with a 1.8 liter, used oversize (96mm) P&C's, put in an aggressive cam with HAM heads. Everyone said the power comes from the cam and head so I did not want to skimp here. I am using the standard heat exchangers and exhaust. The big ticket items were the heads ($1k), carbs ($800) and P&C's ($500). It is a highly recommended combo!
biosurfer1
Nov 1 2008, 11:29 PM
QUOTE(vesnyder @ Nov 1 2008, 09:04 PM)
- maybe a bit more.
Its amazing how many times that phrase is mentioned in the 914 world
Excellent work and thanks for the website documenting it, very informative!
Jake Raby
Nov 2 2008, 05:20 AM
Glad to hear you had such positive results and that I was able to assist...
BUT you know... You could have bought one of my kits for the same cost and you would have been driving a lot sooner :-)
johannes
Nov 2 2008, 02:19 PM
QUOTE(Jake Raby @ Nov 2 2008, 03:20 AM)
I thought you discontinued the 1911 kit ?
Jake Raby
Nov 2 2008, 03:09 PM
Yes I did, the 2056 is about the same cost.. I can put together a 1911 kitasI still have all the directives for it, BUT it wasn't that much cheaper than the 2056 so I discontinued it.
Jake Raby
Yes I did, the 2056 is about the same cost.. I can put together a 1911 kit as I still have all the directives for it, BUT it wasn't that much cheaper than the 2056 so I discontinued it.
johannes
Nov 2 2008, 03:45 PM
He said he spent more than 4 k carbs included ! ... that means 3.2 - 3.5 k for the 1911 engine. Your 2056 kit is 4k ... Your 2.0 crank and rods are cheap
