QUOTE(Bleyseng @ Nov 3 2008, 11:15 AM)
QUOTE(type47 @ Nov 3 2008, 06:35 AM)
my guess is a 2.0 TB would not work because the 2.0 TB mounts to the top of the plenum of a d-jet and so the bottom surface is a flat surface. the intake for a bus/l-jet is a cone shaped surface.
In my situation I am using 1.8 TB which I believe is a direct bolt on.
From RAT/STF threads I believe it reads that the 2.0 'WBX' TB need a little work as far as it's ears. I believe from same research the 1.8 and 2.0 914 TB's are same size throat?
Looking for corrections if I am asumming wrong here...
.....Bley....I will check my research or better yet measure my TB.....
JKP
