RickS
Nov 7 2008, 12:19 AM
Need your expertise... and perhaps a good seat if you have one. I have the original backpad and want to retain it with the replacement seat. I find the stock seat, even in good condition uncomfortable in the seat area. What would you recommend for a good touring/canyon carving seat - without going to a full race seat?
Edit: I'm 6'3' with a 33" waist. Will only wear a helmet with the top off for AX.
Click to view attachmentThis will not be the driver....
TIA - Rick
boxstr
Nov 7 2008, 12:52 AM
This would be my selection....you can find more information, including prices at
www.camp914.com
CCLINSEATINGFORONE
GeorgeRud
Nov 7 2008, 06:45 PM
Have you tried pulling the bottom seat cushion off the stock seat, then replacing it with a piece of 1/2 inch foam? This will give you an additional 1-2 inches of headroom, and is still passable for comfort (depending on your own "padding").
I even considered removing the rear pad from the seat to give additional room. I think a good upholstery shop could probably upholster the cushions in a matching vinyl if wanted. Otherwise, the seats shown are about the best.
RickS
Nov 8 2008, 11:38 PM
Had a Nurburgring seat in another car and it provided zero lateral side support - so got rid of it. Does the seat above have significantly higher/deeper sides? Or, is there a bucket or more high side bolstered seat?
boxstr
Nov 9 2008, 12:00 AM
The LeMans is the best seat for the 914. It has higher sides than the Nurburgring and it slides in and fits into the backpad perfectly.
CCLINSEATINGFORONE
