carcam
Nov 7 2008, 08:24 PM
Mostly stock, rebuilt carbs, checked timing, points, valve adjustment, changed oil. Runs great cold the when warms up, it runs rough, sputters and pops a bit...? Could it be a valve problem, carbs not adjusted correctly or something inherent to the 914-6? This is all new to me- appreciate any help or ideas. Thanks
Rav914
Nov 7 2008, 09:03 PM
Usually with a carb'd six, it's just the opposite. I had a car that had issues when it warmed up - turned out to be a crack in the distributor. When warm the crack would expand, shorting to ground.
I have found over the years, that a quick call to John Walker in Seattle, has solved many problems with a flat-6. He has an uncanny ability to steer you right to the problem. I know this doesn't help anything right now, but give him a try on Monday if nothing else works. Best of luck!
carcam
Nov 8 2008, 08:51 AM
QUOTE(Rav914 @ Nov 7 2008, 10:03 PM)
RAv- thanks, I'll call Monday. Appreciate the advice
carcam
Nov 8 2008, 12:28 PM
QUOTE(carcam @ Nov 8 2008, 09:51 AM)
Nate- How do I reach John Walker, what's his business? Thanks again- we never checked the distributor other than the points gap.
Root_Werks
Nov 8 2008, 12:32 PM
Sounds like your valve lash is too tight.
Root_Werks
Nov 8 2008, 12:33 PM
7613 Greenwood Ave N
Seattle, WA 98103
(206) 789-6800
John Walkers Workshop
Rav914
Nov 8 2008, 01:26 PM
QUOTE(Root_Werks @ Nov 8 2008, 10:32 AM)
I think that may be it. Makes sense. That's also one of the first things to check. I had a '67S that would run terrible if the valves weren't just right. Try this:
1. Check/adjust valves
2. Set points gap. Double check dwell.
3. Clean, check gap on spark plugs. Fouling due to richness can be common if the carbs are out of adjustment.
4. Set timing.
Try that and go for a drive.
SLITS
Nov 8 2008, 01:43 PM
How about something as simple as old high tension leads? Thermal breakdown and arcing when engine gets to temperature.
carcam
Nov 8 2008, 03:46 PM
You guys are great- thanks. Your help on this forum makes owning an old car so much easier. A couple more thing to check tomorrow.
carr914
Nov 8 2008, 06:29 PM
John Forbes @ Black Forest is now in North Carolina and is a 914-6 guy. I dealt with him when he was in Florida. I don't know his # or exact location, but you can look up naro914 (Bob) here on the forum, I know John does work for him.
T.C.
