QUOTE(dempwolf@pctribe.com @ Nov 9 2008, 09:53 PM)
I want a softer ride. I've got Dunlops 205 50 ZR15 in the front and 225-50-ZR15 on the back. I've let air out of the tires, and the shocks are on the softest setting, but the jarring ride is making me NOT enjoy the ride. Don't want to change the entire suspension system since it goes well with motor and brakes. The rims in the front are 7" and 8" in the rear. What tires would you recommend. Thanks Karl
for what its worth, I changed to my winter tires yesterday.
the summer tires are 205/50/15 and the winter tires are 195/65/15
the winter tires are snow tires so they have a much softer sidewall rating...the summer tires are Z rated so the sidewall is super stiff.
I LOVED the ride yesterday for 230 miles...much softer and all the bumps didnt hurt.
So, you might want to try taller street rated tires...your current tires are very low profile (for a 914) and probably are V or Z rated (it would say on the sidewall)
Go down to an H rated tire like normal street cars and you will feel the difference.
As far as what will fit, and still look good....dunno.
I also raise up my suspension for the winter for two reasons.
The winter tires are taller and the snow gets deep around here...
The higher suspension setting also relieves some of the jarring.
If you have a front anti sway bar, try removing one drop link (this disables the system) and drive around like that...it is part of the process to see how you can make it softer.
Rich
