Hello fellow teeners. I am having some horn issues!
I have a 1971 914 (no horn relay) with one stock horn. I recently aquired a dual horn (hi/lo) setup from a 1984(?) 944. There are two connection wires coming out of horns (horns wired in series?), and the two wires coming from the cars wiring harness. I connected the two wires from the horns to the cars harness. The horns will not work. I decided to take a voltage reading at the wire connected to the horn button and it shows full voltage (13.5). I don't think I should be getting any voltage from this wire... it's a ground wire. I also used a wire/voltage probe on the two connections by the horns. With the key to the on position, I had full voltage going into the horns and full voltage coming out of the horns (and heading to the horn button). I know the horns work... I connected them directly to the battery and they sound great. Any ideas on what's going on here?
