QUOTE(r_towle @ Nov 12 2008, 07:17 PM)
Is the crank 78mm or 78.4mm?
I measured it at 78mm
What CR are you designing this motor to achieve?
Undecided yet, but somewhere in the 9.0-9.3 range
What pistons and pin height have you chosen (that will determine rod length)
Pin height is 1.110"... ideal rod length with no shims would be 3.345", which is not an option.
Aside from squaring up the case you should not need to remove material from the case.
You want rods that may be a bit long with no shims and then you use the shims to lower the CR to an acceptable number, your target CR.
From what I understand, CR is set with chamber volume, not with deck height.
5.325" rods look like they will be .020" too short, and something will have to be milled to get me the proper deck height. 5.5" rods will require abnormally big cylinder shims, in the order of .160". 5.5" rods give a better rod ratio, but the type IV already has a better rod ratio than most engines.
Jake can have any shim you need custom made when you figure out what that number is...
FAT does stock some shims, not sure what they have in stock.
Who did you get the crank from?
A guy named Bill
It is counterweighted and has type IV rod journals. The rod journals limit my choice in rods.
Have you called Jake/FAT to ask then what rod they use for your crank?
Rich
No, since I did not buy the crank from them, I did not feel it was appropriate to ask them questions about it. When I do buy parts (rods, pistons, cylinders), then I'd be comfortable asking questions...
