QUOTE(Keoni914 @ Nov 17 2008, 05:06 PM)
Eric, at off the voltage is around 13.xx.
At idle it's moving between 14 & 15 and points in between.
At 2k is ping ponging with WILD swings 12's 13's 14's While the voltage is going back and forth I don't notice any change in the idle.
Do I need, a voltage regulator, a alternator, or another 914?
Another question, is changing the fuel filter a DIY?
Thanks, what a great board!
Keoni914
1. The voltage should be 13.4 volts, so that looks good.
2. You should never see 15 volts. Looks like trouble
2. At 2K, the voltage is ping-ponging with swings in the 12's, 13's and 14's.
Question: Is this measured at the battery poles or at the console meter? If what you're seeing is real, then it would appear to me your generator is on it's way to failing. You could change out your VR, but I've never seen one go bad.
BTW; When you turn on your headlights, does the voltage drop back to the 13-volt level, or does it continue to bounce?
These are pretty hearty generators. For example, when I was changing out the Previous Owner's generator upgrade POS, I purchased a used 914 generator off eBay for $40.00. It was sold to me as a good core, but with no guarantees on it's working out of the box. My thoughts were that I would have it re-wound with new brushes and replace the existing unit. When it arrived, my existing generator was giving me much grief, so I blindly put the eBay generator in my car. Since then (14 months later) I have not had any generator problems whatsoever using the eBay unit!
Maybe I just got lucky. Anyway, you generator is not being regulated properly. Left alone, it will potentially begin burning out your headlights and radio/electronics.
Why don't you do this. Check the wiring between the genertor and the relay board. Look for faulty cable or areas where the circuit can short. If everything looks good at that point, replace the Voltage Regulator with a NEW unit. Replacing it with a unit that is not known good is only going to confuse you more. If that makes no difference, replace the generator.
Once you get this fixed, you will look back and laugh!!! Actually you'll be too busy troubleshooting other areas of your teener to remember to laugh! hahaha!
Good luck!!!
Eric Read
