SOLD AND DELIVERED!!!!
$2000 - Contact Rob 865-463-2575 or send a PM. Please include your email address in the PM if you would like photos sent to you.
Great Restoration Project!
Certificate of Authenticity (COA). It is confirmed that this 914 has option 778 "Can Am" Limited Edition package, matching number engine, and the COA will be included with the sale.
We purchased this 914 from the family that owned it since 1978. It was considered a "lost" LE by the 914 LE Registry, and we supplied the necessary information/photos, and it is now part of the 914 LE Registry.
Most all electrical items work w/ the exception of the side marker light on the pass side and the heater blower. Includes many repair and maintenance receipts, 5 Mahle wheels, front/rear sway bars, dash only has 2 small cracks, front/rear hoods are virtually rust free, build date 3/74, etc. Heat exchangers and muffler not included.
NOTE: An engine lid does come with the 914, but it cannot be mounted because one of the engine lid brackets are broken.
Engine: Matching number engine. GA code block w/ 2.0 Fuel Injection. Evidently the heads, engine sheet metal, and intake were swapped to 1.8 parts. Fuel pump does cycle when the key is turned on, still has a majority of the OE fuel injection system intact. Full engine rebuild done in 1981. Engine does not turn over or run.
Body Issues: Longitudinal and adjacent floor board area on pass side need to be replaced. Needs new rocker panels on both sides. Jack receivers on both sides need to be replaced. Some rust on both sail panels, as well as some other various areas on the body. Minor body damage to both qtr panels.
Delivery possible. Contact us for details.
