QUOTE(914ghost @ Feb 12 2004, 12:38 AM)
...under my shift plate at the front is a small aluminum block...
i know -exactly- what that little aluminum block is ! (i have on ehere just like it.)
you are, or your car has been, at one point, the proud owner of a very early 'short shift' kit ! (probably made by 'Target' Engineering...)
it's probably hard to see without a comparison photograph, but if you have a look at your shifter ball, i suspect you'll find the distance from the upper pivot surface to the lower ball that engages the shift cup (you did replace that too - right?) is about 3/4" longer - the machined shank between the two is made longer.
i had one of those original, unused short-shift kits but i sent the ball off to James Adams (JWest/RennShift). maybe he can post a comparison photograph.
anyway - the aluminum block was supposed to be used to re-align the front tunnel bushing with the lowered actuator ball. i test-tried it in my installation and decided it was too totally hokey, and put too much stress on the shift rod and bushings. what i wound up doing was spacing the base of the shifter plate _up_ to compensate, raising everything to align the lower ball with the correct shift rod placement. you obviously have a car where a PO followed the instructions :-) ...
(the method of creating a shortened shift-lever throw was a common VW practice, but it was easier in the T-I and T-III shifters 'cause you could replace the upper pivot with a hemispherical spacer - they had no antirotation pin to deal with...)
so - if you -do- have one of those extended shifter balls, you need to do -something- to account for the geometry difference - either keep the spacer or pitch it and raise the shifter plate. if the shift lever has been replaced with a stocker, pitch the spacer.
if you happened to replace the shift lever as part of your work, you may just be interpreting the increased shift lever travel as slop. (i find a very short shift travel very nice, and was very glad to have sprung for JWest's RennShift with the max reduction...)
i donno 'bout /4's - on the /6, there is a bushing at the very back (usually covered in guck) that is fairly easy to replace after you remove the roll pin holding the rear shift actuator thingie in place.
if it won't positively engage 5th (and probably you have problems to a lesser degree with 1 and 3 too) the rod will need to be a little shorter.
shifter adjustments are tedious and frustrating, but if you think about what's going on, pretty straightforward. good luck, report back with your progress ...
