QUOTE(southernmost914 @ Nov 16 2008, 12:18 PM)
Looks like you have a early pre 73 engine carrier. Missing bolts part# 900 074 138 01. Bolt,Hex Hd m10X70. I have no idea what is holding your engine in place
Steve
Thanks steve yeah I just bought the car havent really driven it other then home from the seller's. been going over for the last couple of days checking everything out when I loosened the trans mount to remove the heat exchanger I noticed the engine rocking at the front, so I slid foward and noticed the bolt was backed out and the other was missing. I did tighten it but did not replace the missing bolt. however, when I did tighten it and got the car back on the ground it almost sounded like the starter had a tough time rolling over the engine.. I loosen'd it and starter rolled the engine freely.. over reading threw the forums I think I have a starter problem...But for a second I was concernd that the bolt that I had tightened was now grinding on something internally. It seem to get the car to crank i need to hit the throttle any info on this ?
My car Is a 1971 1.7 car runs drives and shifts fine. Only problem is some times starting the car.. I am just going over before I take it out for a nice drive..
