QUOTE(echocanyons @ Nov 22 2008, 01:09 PM)
here is what I am wondering, the top picture is everything that cam with the kit, the bottom is using the stock snubber and the stock top piece.
Do I use the stock top piece with this?, I would like to ues the snubber but I don't know if it is intended to be used without it.
that is about how mine is put together. When the car is on the ground, everything works. I am worried that if the suspension goes off load, like from a large bump at speed, the suspension will float, and may not come back in the desired place. In other words, the hat may not seat in the top of the spring.
I am running mine with out the bump stop at the moment. (250lb springs.)
-- brett
