Heres one way:
http://www.patentstorm.us/patents/6626134/fulltext.htmlAnd an excerpt of the patent text:
The engraving of edge surface 32 is preferably accomplished using a
hand-held, rotating diamond head cutter (not shown). Excellent results
have in particular been obtained using the following equipment: a
Foredom(.RTM. Micro Model FM 1000 engraver; a Foredom.RTM. Handpiece Model
0183; a Diamond flywheel in any of the following sizes: 120, 125, 130,
135, 140, 145, 150, 155, 160, 165, and 180; and a Diamond cutting member,
size 3 mm. The diamond cutting member is also referred to as a burr and an
exemplary cutting member 50 having a diamond cutting element 52 mounted on
the periphery of a head 54 attached to a stem, or shaft, 56 is shown in
FIG. 12 of the drawings. The burr preferably exhibits a 120 degree "V"
shape or profile as viewed in FIG. 12. Cutting member 50 upon being
installed in a handpiece capable of rotating the cutting member at a
rotational speed typically exceeding 10,000 rpm is used to engrave the
edge of a cooling fin to create the preferred vertically stacked rows of
elongated concavities being angled (e.g. acutely angled) with respect to
the horizontal axis 33 of surface edge 32. Contiguous, or abutting cuts or
incisions are made into surface edge 32 and the center of each engraving
is deeper than the ends of the engraving which are located proximate the
edges of the fin, i.e. the depth of the engraving diminishes from the
center of the engraving as it tapers off to the edge of the fin. Thus, a
small part of the original edge of the fin will often remain. The axis 33
of the cutting member is preferably placed at an angle of 45 degrees with
respect to the horizontal axis of cooling fin 18, but may be placed an any
angle when actually engraving each intagliated portion 40. Chamfer 58
shown positioned adjacent diamond cutting element 52 is to ensure diamond
cutting element 52 has plenty of approach clearance when engaging edge
surfaces of cooling fins when engraving is being conducted.
There are many alternative methods that may be employed to create a surface
edge on a cooling fin to have the desired characteristics of the present
invention as described above. Namely, a multi-axis computer numerically
controlled machining center, also referred to as a CNC machine, may be
programmed to create the preferred intagliated surface edge to a depth
ranging upward of 3 mm, or to any other suitable depth. Additionally, the
fins of the engine component may be cast so as to be provided with an
intagliated surface edge and the surface edge being polished, chemically
etched, shot peened, or subjected to any suitable surface treatment known
within the art to provide a desired level surface finish, or brightness.
Moreover, other machines and surface forming and modifying techniques
known within the art may also be employed to provide edge surfaces to
cooling fins in accordance with the present invention.
Other possible embodiments of the engraving are shown in FIGS. 13-18. FIG.
13 shows a combination of ovals 20 that are essentially in the shape of a
Marquis-style diamond, that are cut into surface edge of a fin. Thus, FIG.
13 shows an end-to-end (or horizontal) combination of ovals 20, FIG. 14
shows a side-by-side (or vertical) combination of ovals 20, FIG. 15 shows
an angled, side-by-side (or vertical right angled) combination of ovals
20; FIG. 16 shows an angled, side-by-side (or vertical left angled)
combination of ovals 20; FIG. 17 shows a plurality of x-shaped
combinations of ovals 20; and FIG. 18 shows a plurality of inverted
v-shaped combinations of ovals 20. Any combination of the designs shown in
FIGS. 13-18 may be employed on a particular component of an engine 12 or
on different components of the engine 12.
