For Sale:
1974 914/4 2L w/stock FI $7495 obo
Features:
Ravenna Green with chrome bumpers
Stock 4-cylinder 2.0L D-Jetronic Fuel Injected engine
Low rust chassis; very solid; longs in great shape
Original battery tray w/some surface rust; no rust in hell hole
Stainless Steel Heat Exchangers with Bursch exhaust
Interior in very good condition
Custom flared rear fenders (stock fenders hammered & dollied out)
5-Lug (1987 911) front end; Eric Shea 5-lug converted hubs in rear
Front Wheels: 205/50/15 Yokohama ES100 (75%) on 7 inch wide replica fuchs
Rear Wheels: 225/50/15 Yokohama ES100 (60%) on 8 inch wide replica fuchs
Spare: 195/60/14 on 5.5 inch wide genuine fuch
151,000 Miles
Car cover included
Details
Chassis/Body:
Low rust chassis; Longs in great shape
Door gaps perfect even when jacked up
Surface rust around jack points; no other rust on longs
Original sail panel vinyl with no surface rust/bubbles
Rear trunk floor some surface rust recently sandblasted/primed
Original valences front/rear
Original rocker panels; passenger rocker rust repaired; driver rocker has some rust
Cabin Floors in great shape
3 inch of surface rust around driver side bottom of windshield
Original rear fenders flared with hammer & dolly to fit 8 inch rims
Some surface rust around front body panel behind front bumper (was replaced at one time)
Chrome bumpers: front 73+ (bumperette holes), rear pre-73 (no bumperette holes)
Paint 6 of 10; Front hood repaint doesn’t match well
Driver door has a few scrapes from PO Jersey barrier rub
All rubber in very good shape
Rear trunk key/actuator deleted by inside cable release
Interior:
Black Interior in very good condition
CHT, Ammeter, Oil pressure gauges added
Momo steering wheel with Porsche horn button
Inside mechanical trunk release;
Electric windshield washer
Debounced tachometer (doesn’t jump around when revving or shifting)
AM/FM CD Player
Fire extinguisher mounted under passenger seet
Have New Windshield to install; original is developing a crack (3 inches).
Engine:
2L with stock Fuel Injection
Unknown rebuild history
Runs very well; doesn't smoke; doesn't leak oil
Pertronix electronic points
Heat flappers recently sandblasted, painted
Stainless Steel connect pipes from SSHE to flappers
Front mounted fuel pump
Fuel tank recently cleaned & repainted
Bursch sport muffler w/chrome tip
Optima red top battery
Transmission:
New clutch, pressure plate, throwout bearing, transmission main shaft seal, clutch cable
Sideshift transmission; shifts very well; can get 1st gear easy while moving
Oil changed last year
Front Suspension:
From low mile 1987 911 Carrera including:
struts, hubs, calipers, Aluminum crossmember, steering rack, underbody swaybar, A-arms, T-bars, tie rods
Rear Suspension:
180lb progressive rate springs, Koni adjustable shocks, stock swaybar,
Eric Shea 5 lug drilled hubs, new bearings, stiffened swing arms
Stiffened trailing arms
Brakes:
Front: 911 3.5inch A calipers
Rear: rebuilt (3 years ago) stock rear calipers
Functional front brake pad wear sensors (brake light flashes when pads worn)
19mm Brake Master Cylinder
Rear Brake Proportioning Valve replaced by T
HISTORY
The only history of the car I could find that it was owned for many years by a gentleman in CT. Racer Chris did some work for him including the time he hit a Jersey barrier with the left rear corner and he replaced the trailing arm and brake caliper. In April 2002 Chris did the PPI for a 914 board member. At that time the car ran well, had good compression on all cylinders and needed no rust repair at all. I bought the car in March 2006.
At some time in the past the car was hit on the drivers front. The inner wheel well was creased and the front panel behind the bumper was replaced. The hood was repainted at this time.
See much of the work I’ve done to the car in this thread:
Progress Thread
