QUOTE(Phoenix-MN @ Dec 1 2008, 07:13 AM)
Are you sure it hits the lever? I had a problem with the shift rod hitting an internal bracket.. I had to cut an access hole and grind the bracket opening a little larger.
Click to view attachmentThanks for the pics, now I know where to open mine...
That's exactly where my shift rod hit when going into First/Reverse, I got tired of the squeek and sprayed white grease on the rod and that brace, but I know it will come back!:angry:
