Hi all,
I've recently gotten my 914 running under battery power! 200 miles on it so far, up to 70 MPH without topping out. I've got several electrical issues on the low voltage side, but my biggest issue is vibration from the transmission. With the little electric motor instead of the larger gasoline motor, vibrations in the transmission at about 3,700 rpm tries to shake the car apart. Given how quiet the car is at lower speeds, I really want to fix this problem.
I am looking for a shop around LA that can do the following:
Minimum:
- Rebuild the transmission/differential to make it quieter (the gears whine loudly, especially when down shifting)
- Try to balance the parts to minimize vibration
- Grind the teeth off the flywheel (no starter)
- Balance the flywheel (attached to the electric motor)
Goal:
- Drop the gear ratios*
- Dynamically balance the motor/flywheel
Any advice?
Thanks.
* At 70 mph I was still in 3rd gear so I don't need the upper gears much, but it is hard to start quickly on steep hills with the weight of the batteries (~1,000 lbs of lead). If I drop all the gears such that the current ratio in 3rd becomes fifth and then drop the others accordingly, I can drive it as a 5 speed and have much better torque on steep hills.
