Hello fellow ninefourteeners,
Help me raise money to justify buying more stuff for the garage.
Here is a set of cylinder head tin for a 2.0 engine. Looks like the driver's side tin was repainted at some point. It has a small crack at a mounting hole, toward the front of the car, I've tried capturing it in the pictures. No cracks around the spark plug area. Also looks like someone welded a small nut to the underside of the small hole, where I believe the ignition wire clip usually snaps into. The passenger side tin has surface rust, but no cracks that I can find. It could use a bead blasting and repaint. Otherwise, it appears to be in good shape.
$50 + shipping from 97124. Box size is 22" x 19" x 10". Shipping weight is 7.5lbs. I'll calculate shipping using the USPS shipping calculator
PayPal please...
12/7/08 - Off to Ebay...
