QUOTE(ericread @ Dec 5 2008, 10:01 AM)
As I prep my car for paint, I will need to be replacing the outer door window seals - the ones that sit horizontally on the door where the window enters the door.
Has anybody used these, or can anyone reccomend a different vendor that supplies these seals?
My thanks.
Eric Read
they are available in repro or original depending on the level of your restoration. we install them by sliding in from the back with silicone grease and inch worming them in. You should also remove the vent window seals when painting the doors.
