turnaround89
Dec 5 2008, 12:09 PM
I just bought the Empi 40 HPMX dual carb kit and had a question about them. The single carb has an electric choke and the dual carbs do not have an electric choke like the single carb. Am i missing something or is this how dual carbs are set up?
ws91420
Dec 5 2008, 12:29 PM
no electric choke on duals
rhodyguy
Dec 5 2008, 01:00 PM
the fuel enrichment/high startup idle device is to the right of the brake pedal.
IronHillRestorations
Dec 5 2008, 01:16 PM
No choke, and you won't need it. Use your foot as fast idle until your engine warms up.
So.Cal.914
Dec 5 2008, 01:24 PM
QUOTE(rhodyguy @ Dec 5 2008, 11:00 AM)
My duels flood easy, one pump in the morning before you attempt to start it. When it fires then you do a Rhodyguy and keep the R's up till warm.
turnaround89
Dec 5 2008, 02:13 PM
Wow, so thats what that enrichment thing does that has the cover on it. thanks everybody. When i try to start the car ill just have to pump the gas pedal, i have to do that anyway with the single carb. Thanks again!!!!!
