Pretty easy...it'll come out in one big assembly....
Rough instructions:
Remove nut on top of shocks,
Remove bolt from the universal joint in drivers compartment for the steering linkage.
Remove gas tank to remove the U-clamp on steering shaft.
Loosen brake lines to calipers,
Remove the 4 bolts that hold the front of the a-arms to car,
Remove the 4 larger bolts that hold the steering rack to the car...
Gravity should do the rest
Good time to inspect/replace the mastercylinder
I'm sure I forgot something, but you get the general idea.
Mike Mueller
