Yep....out on a 55+ day here in the DC area on a newly rediscovered back road when I noticed my throttle wasn't returning to idle......so I stop and look and cant see any binding , blip it and off I go as itseemed well, going back towards home that is....well within the space of 5 min it got worse went from a 1500 idle to 3-4 k idle and I pull over again.
look under look uptop and I notice it has gotten REALLY stiff! so I start wigglin and wagglin pieces then taking off ball connectors and WHAM problem found.
It was the bell crank do hickie on the carb manifold...the one that joins the crossbar rod to the through the tin to the tranny crank...it was stiff as shit.
Well I know I greased it since putting it on (only about 100 miles maybe 200) and it was cool to the touch...so what gives! I needed to get towed...Merry christmas eh? Only thig I can think of is the supper tight tolerances and the whatver you call it of dissimilar metals ( bronse and SS) caused something weird to go down....either way I couldnt pry that thing off! it bent and now that whole bank needs to come off to fix it....ARGH!
BTW you sixer gut's will know what piece to which I refer
