VaccaRabite
Dec 29 2008, 04:55 PM
When I put this stuff in, do I need to glue it down?
If you glue it, how do you get to stuff in the tunnel?
Zach
PeeGreen 914
Dec 29 2008, 04:58 PM
The 4 914s I have had only had glue on the longs, Foot well and tunnel. The other pieces just sat there like floor mats. I don't know if they were correct but they looked good.
What goes IN the tunnel?
r_towle
Dec 29 2008, 05:02 PM
glue the side of the long.
Glue the piece on the drivers side foot well area.
I dont glue anything else
Rich
tod914
Dec 29 2008, 05:53 PM
I wouldn't, incase you want to or need to clean them. The long pieces are held in by the inner threshold strip. The speakers secure the foot rest pieces, the defroster button holds the center piece in place. Give it a try without, then go from there. Maybe if you want a more secure fit, you could try some velcro, but don't think it's needed.
xperu
Dec 29 2008, 06:13 PM
Zach, I used Velcro to keep it on place in the tunnel area and the pan areas; it keeps it in place very well. Mike
Slick914
Dec 29 2008, 06:46 PM
Velcro sounds like a good idea.
I used double sided carpet tape on mine. Strong enough to hold it in place, but you can still pull the carpet up should the need arise.
GaroldShaffer
Dec 29 2008, 06:55 PM
I just did the Morph carpet kit in my 70. I glued everything except for the floor pans. I used the 3M carpet/headliner glue. It has just engough hold to hold the carpet in place, but if needed I can pull it up and re-glue later.
maf914
Dec 30 2008, 11:47 AM
QUOTE(r_towle @ Dec 29 2008, 03:02 PM)
Rich
On my 76 the center tunnel carpet is held by the heater lever light fixture which screws into the tunnel. In original carpet sets this piece is sort of molded to fit the tunnel. The sides of this carpet piece are covered and held down by the left and right main carpet sections.
