I replaced the muffler on my Bursch exhaust with a Magnaflow and made before and after sound clips. I was hoping the swap would give me a more aggressive sound and better flow. It really didn't make a big difference in sound. If anything, the Magnaflow muffler might be a touch quieter. Guess I'm just used to the rumble of my Chevy v8's and was expecting too much. It does have a little deeper sound to it. It also has to flow much better because it is a straight through design. Sure was a pain to install because the case is a little bigger and it had to be just right to not hit or rub anything. I had to make a little dimple on the muffler in one spot to clear one of the exhaust hanger bolts up top.
My conclusion: It sounds fine, but it's not the grunt I was hoping for. If I would have known the outcome before doing the swap, there's no way I would of done all that cutting, fitting, and welding. Probably not worth the effort unless you're looking for a better flowing muffler or your current muffler is rusted out.
Here's the sound clips (might have to turn up your volume)....
Bursch Muffler... http://www.supload.com/Bursch-download-U1vpbM.html
Magnaflow Muffler (part# 11124)... http://www.supload.com/914-Magnaflow-download-XCQ1HM.html
