mojorisen914
Jan 1 2009, 09:16 AM
Happy New Year everyone.
I need some advice; can I run a hose from one head to the other, put a T in the line and vent both heads back to the oil filler nipple and still let the heads breathe or will this cause a pressure lock in the system?
An Inquiring mind needs to know.
Joe Owensby
Jan 1 2009, 09:19 AM
You need to add another line to an external vent. CB Performance, and others sell a simple box that allows the lines to connect and vent any pressure outside while minimizing the oil vapors that excape into the engine compartment.
ChrisFoley
Jan 1 2009, 09:20 AM
at a minimum you need to have the crankcase open to the atmosphere.
for instance, tee the head vents together. Then run that hose to a tee with the oil filler fitting, that has a small vent filter on the tee.
ericread
Jan 1 2009, 01:32 PM
Are you running carbs or original FI? That will make a difference.
Eric Read
ottox914
Jan 1 2009, 09:06 PM
Buy the CF breather tank. Not cheep, but works as it should.
Go to page 8 on this thread for product and install pics:
http://www.914world.com/bbs2/index.php?sho...5883&st=140Its a great piece, and no, I didn't get a deal on one in exchange for posting about how well it works- I paid full $$$ just like anyone else.
r_towle
Jan 1 2009, 09:26 PM
QUOTE(mojorisen914 @ Jan 1 2009, 10:16 AM)
you will create to much pressure with no place for it to release.
Wont work.
Rich
mojorisen914
Jan 2 2009, 12:29 AM
I'm running carbs. I plan on buying the vent box/tank sometime in the future. Thanks for the advice everyone.
