QUOTE(ericread @ Jan 2 2009, 05:09 PM)
You guys are right.
I don't know what I was thinking
Once I complete the etching primer I will take it to the painter. He plans on performing a light sand anyway.
Thanks - and never mind...
Eric
Eric I don't know if you are using the term " etch " primer generically or not but true etch primer is meant to be put over bare metal only. It is not to be used over filler. It won't hurt if a small amount gets on the filler but you shouldn't coat the whole thing with etch.
Epoxy primers on the other hand can be used over bare metal and filler.
Sealer/high build primers are for using over filler and SMALL spots of bare metal. As a rule of thumb if I have a spot of bare metal larger than a quarter I will put a touch of etch on first then topcoat with a sealer.
As for wet sanding, 400 should be done wet, and would be preferrd by the painter particularly if he is going to put a light sealer coat on the car prior to the base color.
