I have Koni reds and 200lb springs and I would like to add adjustable perches. My search led me to Coleman racing, but I can't figure out which kit is correct.
5" Coil-Over Kit (2.04 I.D.) $42.75
5" Coil-Over Kit (2.08 I.D.) $42.75
7" Coil-Over Kit (2.04 I.D.) $42.75
7" Coil-Over Kit (2.08 I.D.) $42.75
8" Coil-Over Kit (2.04 I.D.) $42.75
8" Coil-Over Kit (2.08 I.D.) $42.75
I measured from the center of my shock bolt to the base where the springs rests under a load and that meaurement is 8 inches. I would like to be able to drop the rear height about 1-1.5 inches.
Do I have to remove a shock to measure it's diameter? Also, don't quite understand what the 5, 7, or 8" option refers to...unless its the 8 inches that I measured. If so do you buy a shorter length to drop height or go with the same measurement?
Thanks
