Update of the whining trans,
First of all, you really have to excuse my bad english, I live in sweden and here we talk swedish, a language that in fact sound like the swedish chef in the muppet show...
I wanted to send my trans to Doctor Evil but the shipping costs was 300-400$ from sweden so I that was not an option in the end. This sunday, I was really bored, so I spended a day in the garage, I had to fix up the vaccumlines to the engine and change some gaslines to the gasfilter, I quickly realised thet everything should be easier if the engine was out of the car.....(I know, bad idea)
And when the engine was out, It would be nice to clean up some mess in in the enginroom.....
Chop, chop... and 500 profanities later over the CV-bolts (I will change them all this time, I hade 3 different types right now)
What the heck, as the engine is out now, It would be a perfect time to fix the whining on the 4th and 5th gear... and when Im in the trans it would be a quick fix to change the syncrings for the 1st and 2nd...
First "surprise", really bad dogteeth on the 1st, the slider was good tough..
The PO had at some point (He did tell me when I bought the car) driven the car with to little oil in the trans so I suspected that some bearings was bad, and that was the reason to the whining on the 4th and 5th...but the bearings looked ok at the first sight, unfortunaly I found something worse...
The ring gear and the pinion shaft looked really bad.....
And the ring gear was not far behind in the beauty contest....
To shims the ring gear is far above my knowledge so I have will leave it to someone in my area who knows what to do...
I will take a better look on the bearings, I can't understand why the whining only occurs on the 4th and 5th, the damage on the pinion looks worse on the pics so maybe the whining is created somewhere else...
I'm thankfull if someone has a second opinion on this...
