carcam
Jan 10 2009, 08:40 PM
914-6, mostly stock, runs perfectly on the gas. When lifting off it pops a little, sometimes, not every time. When going down hill with no pedal, no gas, it pops like crazy, almost like a backfire. New plugs, wires, points, etc. Timing seems OK, valves adjusted exactly...what else could it be? It's probably something simple I'm not thinking of or maybe something major? Appreciate any insight- thanks.
KaptKaos
Jan 10 2009, 09:11 PM
Air leaks around the intake or exhaust.
cwpeden
Jan 10 2009, 09:20 PM
My vote is for intake leak.
carcam
Jan 10 2009, 09:34 PM
QUOTE(cwpeden @ Jan 10 2009, 10:20 PM)
Just had Webers rebuilt with all new gaskets but I'll double check everything. Thanks.
r_towle
Jan 10 2009, 09:42 PM
QUOTE(carcam @ Jan 10 2009, 10:34 PM)
May not have them tightened down to the manifold.
Go re-tighten all the bolts that were off for the rebuild.
Rich
carcam
Jan 10 2009, 10:05 PM
QUOTE(r_towle @ Jan 10 2009, 10:42 PM)
Rich
Another project for tomorrow- can't wait! thanks
proto31
Jan 11 2009, 12:25 AM
My vote is for the carbs being too lean. Richen up the fuel mixture...
NORD
Jan 11 2009, 12:26 AM
I was infested with motor popping on decel, checked all elect, valves,even
adjusted valves over and over they were always good. Checked for vac.
leaks all OK. I found my carb linkage was closing down one bank of motor
1st and they were not adjusted perfectly. I have a 4 but look at this on
your motor, linkage adjustment solved my problem
carcam
Jan 11 2009, 08:20 PM
Can't wait to try all these remedies- after years of new cars, it's really fun to have an old car with an assortment of maladies waiting to be fixed. As soon as i can get out to the garage, I'll get back---
SGB
Jan 11 2009, 11:13 PM
I vote for the rich mixture and/or exhaust leak...
Lavanaut
Jan 12 2009, 01:50 PM
I had the same
exact symptoms on my /4, it was an exhaust leak. That's an easy one to check for too...start your car, block/cover the tail pipe, listen for hissing. If you don't hear anything and your engine stalls you can probably cross it off the list.
In my case, one of my heat exchangers was damaged inside the clamshell. Given what HEs for a /6 cost, if you can even find a set, I hope that's not the case for you!
carcam
Jan 12 2009, 09:35 PM
More things to check- thanks! Can't get to it until Friday- too many root canals to do...
