I just typed a whole bunch of instructions but something happened when I clicked on it to post...
This rotor is part of a rear disc brake conversion for a friend of mine. They are for a VW Fastback. I center the rotor on my round drill press table using the pointer end of my caliper.
Then I use a wheel spacer. I bolt the spacer to the rotor with one lub bolt. I center the spacer on the rotor with the pointer end of my caliper.
I have a small hole pre-drilled through the spacer. Once the rotor is centered I complete the small hole through the rotor. I leave the drill bit in the spacer and rotor. This keeps the rotor from moving.
I use a large bit the size of the hole in the spacer. I use the large bit to make a center mark in the rotor for a bit the size of the stud.
Once I did my rear rotors for my 914 I bolted the rotor to my rear flange and used a big ass hand drill through the spacer to mark the hub flange. I drill out the hub flange without removing it from the car.
