BravoHotel
Feb 18 2004, 02:31 PM
Anyone running these tires. What kind of pressures are you using? Autocross and DE.
Thanks
BH
Demick
Feb 18 2004, 02:37 PM
I run them (Victoracers) at autocross. They are pretty flexible as far as tire pressures go. I would start at 30 (cold) all around and adjust from there. If it is a smooth high grip surface, I usually go higher (like 35 cold).
Demick
J P Stein
Feb 18 2004, 02:44 PM
They worked best for me at 26 psi, cold.....at AX,but that's with -2 camber at both ends. The tires roll "some" with pressures that low. Here a pic...rerun. Look at the side wall of the rear tire.
john rogers
Feb 18 2004, 03:04 PM
I agree with JP, 25 to 26 cold if you have a 4, a pond or so more in the rear with a 6. These are for an autocross and for a DE or time trial with continuous laps I'd set the pressures to 26 hot front and rear. Try to find someone with a pyrometer and ask them to read tire temps for you. Good luck
campbellcj
Feb 18 2004, 03:37 PM
I used to run the Kumhos much higher, about the same as Hoosiers (38-40 hot). Then Tyson Schmidt from TRE told me he gets much better grip at 24-26psi, so I tried it, and the difference was major.
ChrisReale
Feb 18 2004, 04:49 PM
I SHOOT FOR 27 COLD
Andyrew
Feb 18 2004, 06:50 PM
What about street tires?? Im running 30 all around (I think)
I bet its too high..
andrew
