2-OH!
Feb 18 2004, 04:58 PM
I am taking the short block down to take care of the Galley plug issues and while I am down, I should go ahead and polish/rework/replace the cam.
Local guy has quoted about $250 just to polish...
Whats a replacement worth ???
Daily driver, stock FI 2.0 engine...I don't yet know the condition of the cam until I get down futher...
93,000 miles
What do ya think...
2-OH!
Jake Raby
Feb 18 2004, 05:04 PM
Damn!
Never heard of polishing a cam.. Sure he is not talking about the crank??
Watch this guy very closely, sounds more thana tad fishy to me.
I'd like to know how he polishes the cam-
Mark Henry
Feb 18 2004, 05:10 PM
QUOTE(Jake Raby @ Feb 18 2004, 03:04 PM)
400 grit sandpaper <_<
Find a different guy.
Jake Raby
Feb 18 2004, 05:56 PM
Damn.....
Sure thats a shop and not a slaughterhouse???
tat2dphreak
Feb 18 2004, 05:59 PM
ummm... won't 250 buy a webcam? cheaper to replace than fix IMHO... get a new one.
Jake Raby
Feb 18 2004, 06:14 PM
Maybe I should have this guy polish a cam and let me test it in my fixture...
seanery
Feb 18 2004, 06:23 PM
webcams are 155 if you don't shop around 140 if you do.
Mike D.
Feb 18 2004, 06:31 PM
Damn, for 250 I've had everything cleaned checked balenced and ready to go... find another shop... One that doesn't say PORSCHE on the outside...
2-OH!
Feb 18 2004, 07:24 PM
Thanks guys, The Bird has the Web cam for $135.00...If I replace the cam, should I replace the followers...The old ones are perfect...Not a mark on 'em...
2-OH!
DuckRyder
Feb 18 2004, 07:30 PM
GOD YES
McMark
Feb 18 2004, 09:39 PM
Duck, I think you meant...
GOD YES
seanery
Feb 18 2004, 09:42 PM
....what they mean is....webcam says you need to. I'd do EXACTLY as they say, especially with the failures of cams/lifters.
DuckRyder
Feb 19 2004, 07:38 AM
In light of the cam lifter problems that have occurred lately:
This is strictly opinion, but assuming that you kept the lifters in order when removed, I would closely inspect the cam/lifters. If they are good then I would probably reuse the set.
If you did not keep the lifters in order or the cam shows flat lobes you have NO CHOICE but to replace both cam and lifters. Unless you want to step up to the ceramic lifters get the WEB CAM recommended set.
Some here may disagree, but also I would go to Summit Racing or Jegs and order both the cam lube and oil additive from one of the major hot rod cam people like Crane or Comp and absolutely cover the thing with it. When you think you have way too much on it, put some more on. If you run out, you might have enough on it.
If the lifters or cam is indeed improperly hardened, the lube won't save it, but many a perfectly good cam had been destroyed by poor oiling in the first few minutes.
When you fire the new engine off you must run it at least 2500 rpm for 20 minutes minimum. Do not let it drop below 2500. Every person has kind of a preferred procedure, but nearly all, if not all Cam manufactures say above 2500. I personally run mine at 2800-3200 (I gradually vary the rpm between those two) for 30 minutes.
rhodyguy
Feb 19 2004, 07:51 AM
do you mind saying who the "local guy" is?
kevin
2-OH!
Feb 19 2004, 12:03 PM
Kevin:
Sent you a PM ...
2-OH!
