QUOTE(r_towle @ Jan 18 2009, 03:27 PM)
Old stock springs will sag and do this.
If you replace the springs with new ones it should go away.
If you choose to just adjust the camber, take a look at the three bolts that hold the outer adjustement point for the rear trailing arm.
Between these bolts and the frame of the car are camber shims.
So, to adjust the camber on the rear, you need to acquire more shims.
Used (ask in the classififeds)
New, go to Engman in the member vendor forum.
Rich
I was thinking of buying 100lb springs but i didn't think this would fix the problem for sure, what should i buy 90lb or 100lb?
Thank you
