kconway
Jan 18 2009, 10:05 PM
I've seen coils mounted to the fan shroud using a bracket. Is this a OEM application and bracket or aftermarket? Where does one find said bracket. Any disadvantages to mounting it on the shroud?
Kev
kconway
Jan 18 2009, 10:07 PM
Crap! Wrong forum. Sorry. Admins...a little help pleez.
cwpeden
Jan 18 2009, 10:45 PM
I think a buddy of mie had his on the tin. After a few years of autocross and suspension upgrades the nuts in the tin ripped out.
He has his on the fan housing now without problems.
Mine have all had a small plastic screw in the fan shroud hole, I think its for the buses.
McMark
Jan 19 2009, 12:53 AM
The garage is an appropriate place for this.
AFAIK, the 1.8s all had the coil on the shroud. You just need to post a WTB or call one of the part yards (EASY is my favorite).
ConeDodger
Jan 19 2009, 01:13 AM
QUOTE(McMark @ Jan 18 2009, 10:53 PM)
Isn't it an early vs. late thing?
The early having the shroud mount and the late using the tin? I have a set of tin with the coil mount ripped loose too... I went to the shroud mount but I believe mine was made by Spunone...
Katmanken
Jan 19 2009, 09:09 AM
Well to add to the fun, the Bosch blue coil is smaller in outer diameter than the old stock black coil....
Use the fan mount and bracket, and you will find that the Bosch Blue is just too small and can't be held by the stock parts.......
Ken
Cap'n Krusty
Jan 19 2009, 09:45 AM
The shroud mount was used on (GASP!) VW busses. Tin mount on 914s. I have a few brackets for anyone wanting the non-stock confriguration.
The Cap'n
craig downs
Jan 19 2009, 11:24 AM
Hmm my original 1.8 came with the coil mounted on the shroud.
McMark
Jan 19 2009, 01:29 PM
Yeah, the 1.8 I'm working on now has it as well. And in fact, the tin does not even have mount holes for a coil. That's new on me.
Jan 19 2009, 01:33 PM
My 1.8L motor had the shroud mount as well ...
Andy
So.Cal.914
Jan 19 2009, 01:42 PM
My 1.7 was on the tin.
7275914911
Jan 19 2009, 03:32 PM
My 1.8 is on shroud.
No evidence of holes in tin either.
jkp
