Early Spring Cleaning.
Payment: I'm flexible. Paypal, check, money order....send me a PM and we'll work something out.
Shipping: buyer pays shipping. I've included shots showing weight. Add a few pounds for packing and go to UPS.com to get a ball park on the shipping. I can also meet up with you somewhere on the I-91 corridor, or in the NJ metro area if you can wait a month or two.
$100 5 "western" style wheels 5.5" wide.
4 of them are manufactured by Dan Gurney Industries. While clean and straight condition is only fair. The 5th is unmarked and visually slightly different. It's also a little out of true. Was recently used as a spare, but I wouldn't use it all the time. I've included picts with the worst of the damage. They will not fit a 205 tire on a 914 with stock rear fenders. They also require flat seat lug bolts. 4 of the lug bolts I have are partially stripped. I will include them if you want them.
$100 Patrick quick six mounting bar
Mounts to the 4 cyl mounting points using sport mounts that are NOT included. I broke this bar after about 6 autocrosses. I repaired and reinforced as pictured. I only ran 1 autocross after repair. I've since gone to a RJ mount. If you are doing a 6 on the cheap and don't autocross on R comps on rough lots this is your mount.
$100 pair 944 turbo stub axles with nuts and washers PN 951.332.235.01
see below for picts. For shipping figure 10lbs 9x9x7 box.
WTB:
upper 2 pieces (not the part that attaches to the carbs) of a 911 air filter assembly
Pair of dust sheilds for 3" caliper bolt spacing 911 struts.
Kelly
